LED flasher?
Old May 6, 2010 | 02:24 PM
MudTerrain's Avatar
Post LED flasher?
I've installed LED switchbacks in my front turns and need an LED flasher to correct the "hyperflashing".
I've gotten under the dash and found the flasher (looks rather big) and it appears to be held with a 'star-headed' screw. I'm at school right now so I don't have any tools to remove it and see if the flasher is indeed there, and to see what the flasher looks like (number of pins).
Does anybody know the part number of the flasher (or pin configuration)? Link to buy it? I know through searching on the forum the '04+ trucks use the EP-27 flasher...
Thanks for any help.
Old May 6, 2010 | 03:13 PM
thejake1989's Avatar
no tools are required to remove the flasher. its just under the dash, and ours are 5 pin but idk the number
superbrightleds.com has them
Old May 6, 2010 | 04:26 PM
MudTerrain's Avatar
Ok, yeah I was looking at something else.
I found the flasher and after about 10 minutes figured out how get it out from under the dash so I could remove it.
I'm getting one ordered ASAP! Thanks for the help.
