Viper Progressive lock help
I hope this is the right forum, I purchased and have installed a viper 5701 alarm/remote start.
However I can't find any information on how to make the factory ford progressive locks work with the 5701.
I can do an all lock and all unlock, but i would like to be able to unlock only the drivers door first then choose to unlock the others.
Can anyone help me with how to accomplish this?
Thanks in advance, Donnie
that has to be set up by the installer. in order to do this the 2nd unlock wire on the alarm needs to be hooked up. basically, the installer needs to connect the regular unlock wire to a relay on the drivers door unlock wire and then the 2nd unlock wire to a relay to the wire its currently connected to.
its something we charge extra for at my shop because of the extra relays and labor.
Thanks, for the information, I know i have to isolate the drivers door motor with a relay I've done that i need to know what to use to trigger it,.The viper 5701 does not seem to have the second unlock wire.
edit: for those that have the new Viper 5701, the wire is no longer light blue 2nd unlock wire. you have to use AUX1 and go into the programming menue and move it to feature 6.
