guage cluster
It will ( assuming you have the same cluster type i.e. 4WD ) but you need to do 2 things after installing the cluster.
1. Have the PATS keys in the HEC erased, and your 2 PATS keys programmed to the new HEC.
2. Have the PCM_ID erased in the cluster, so it can learn the new PCM_ID from the PCM in your truck.
