2004 F150 Airbag light flashing
I know what's wrong, error code 18, I'm just wondering which would be better; to replace that harness, if possible, or just solder in a new LED.
I'm nearly positive that just the new LED would be a good deal cheaper.
Also, where do I need to start the dash disassemble at?
I know how to get the glove box and the cover above that off as well as the panel below the steering wheel but I can't seem to get the middle out, no center console, just can't get the radio and everything out.
Are you doing this on a column shift or a center console shift? On my center console shift, I just open the ash tray and remove the trim around the radio by pulling the bottom first and working my way up to the top of the dash.
