Conflicting cluster swap out information
Ok so after an exhaustive round of research I found out that there are members out ther that have indeed swapped to a lariat cluster.
Lariat clusters which they had flashed and then rigged up the message center controls in order to get everything working properly.
However in another thread I found that the lariat clusters will not let the AC work in trucks other than lariats or ranch editions. This is apparently due to the lack of the digital automatic climate control.
If you search the posts' names are as follows:
Therefore, will a 2007 lariat cluster work in my 2007 FX2 that is not equipped with automatic climate control and has the standard manual AC control?
Come on ford fans!! lets put this topic to rest once and for all!!!!!!!!!
Thank you for your prompt attention.
- Lariat Cluster in My XLT
- Lariat Cluster wont take "as built" data
