Help with 2005-2006 fuel pump cable wiring
What do you need help with ?
The Fuel pump driver module is the same for 04-08 MYs.
The fuel pump circuit should be plug and play, if you installed all the items.
Thank you for your quick reply...i need help with the connection cables the 06 was Red/Blk -Yellow/Wht -Brown/Pnk- Red...The 05 was Red/Bkl -Brown/Wht- Yellow/Wht -Brown/Pnk....See Attach.
Regards,
A.O
Regards,
A.O
