Right turning signal doesn't flash
Hi, I have a 2006 F-150 5,4 XLT Crewcab and since one week, my right turning signal doesn't want to flash, it stays open in my dash but dont flashes as my front and rear bulb too. The left is ok, it works perfectly. When I put my hasard, both flasher dont want to flash, they stay open but dont flash. Since I have that problem, my doors doesn't lock as asual when I take speed, they only locks when I put my right flasher !?!?. Have you ever seen that kind of electric problem ???? Also, I have a remote starter from OEM Ford in it and the remote doesn't work properly since 1 week too, so maybe the problem start there, dont you think ?
Thanks for your help, and sorry for my English...
Charles.
Charles.
Sounds like you need to check both door sill wiring harness for water damage.
The wires run door the door sill, and some times water can get into the channel, and cause problems.
The other thing to check are the connector in the driver's side kick panel, to make sure they are together.
Thanks Scully,
I'll check that tonight. In the meantime, anyone has an another idea before I begin ? Does anyone have heard any problem with the remote starter that could be in line with my electrical problem ?
Thanks again !
Thanks again !
