Need help with cig lighter and 12v plug please
Guys my ******* brother inlaw got in my truck the other day with me and saw my cell phone charger was pluged into the 12v plug and it was not in there straight,so he turned it without pulling it out of the plug and now that dont work and the cig lighter dont work,Could it be a fuse and is so anyone no where it would be and what one,My son did something with my manual..Thanks for anyhelp guys
Craig
Craig
Yes there should be a primary fuse for the IP Cluster that goes directly to the "Cig Lighter" or the combined Power-Cig Lighter Circuit. Depending on your car's configuration you should find it easy. Normally it is a 20-25 Amp fuse. Since I don't know what exactly you are driving; check your ownership manual under "Fuse Locations". My Exp'y has two fuses tasked for each power jack.
Don't know what MY truck you have to offer some advice, aside from download the PDF version of the manual from Ford :
https://www.fleet.ford.com/maintenan...ls/default.asp
