what wire is 12v on the head light switch on a 2006?
Old Jan 30, 2010 | 01:21 PM
Heith's Avatar
Question what wire is 12v on the head light switch on a 2006?
On a nbs ford which wire is 12v so I can tap it to run the swtich for my after market fogs.
Old Jan 30, 2010 | 05:54 PM
SSCULLY's Avatar
What do you want to trigger the relay, the parking lamps or the headlamps ?
Old Jan 31, 2010 | 11:34 AM
Heith's Avatar
It would be nice to be able to turn them on with out the parking lights. Right now I hooked it to the brown wire and it allows the fogs to turn on only when the parkinglights are on.
Old Jan 31, 2010 | 11:39 AM
SSCULLY's Avatar
If you want to be able to turn them on without any headlamps on, you need a hot in run / accy position wire, not a wire from the main headlamp switch ( those are all hot at all time, and go to the headlamps or the parking lamps / instrument illumination.
If you use an Add-a-Fuse in the radio fuse slot, this would give the function you looking for, without being able to drain the battery.
Old Feb 1, 2010 | 05:42 PM
Heith's Avatar
thanks
