LED flasher relays
Old Apr 5, 2012 | 12:20 PM
  #31
Bshipe22's Avatar
Originally Posted by SSCULLY
If it is a single wire and the mounting bracket is ground, if I got that correct, you are right,you made a loop from parking lamp circuit to stop / turn circuit.
The brown wire is the parking lamp circuit, the other wires that you ID'd are stop / turn for each side.
If I got it correct, the LED lamp you have is a single circuit only.
Either to the Stop / Turn circuit on each side or to the parking lamp circuit on each side, but not both.
So if I want my brake lights and turn signals I need to just undo the parking lamp wire? Also would that be considered a flashing red light to the cops. It would be off until I hit the brakes ans use blinkers right? And thank you for the help!
Old Apr 5, 2012 | 02:41 PM
  #32
SSCULLY's Avatar
If it is a steady burn light when the brake lamps are on, or only flashes at the same rate as the turn signal, you should be fine with the police.
Think of it the same as the line of fire bars under the tailgate.
If you want it to be stop / turn only, remove the wire from it to the parking lamp circuit on both sides and it should return to normal.
Thing is how useful it is going to be as a stop / turn lamp, don't know how bright it is, lumen output wise.
Old Apr 5, 2012 | 04:33 PM
  #33
Bshipe22's Avatar
Thank you problem solved. Just created a loop.
