Fuel pump lead wires
Old Jan 2, 2010 | 09:17 PM
shiftonthefly's Avatar
Would any one know what color the lead wires are coming from the electric fuel pump.The truck is a 2002 FX-4.I need this to install a filter to reduce the electrical noise emitting from the pump. Thank you
Old Jan 2, 2010 | 10:55 PM
SSCULLY's Avatar
The 5.4L V-8 diagrams show :
Fuel pump relay to Fuel inertia switch is Dark Green w/ Yellow stripe wire
From the Fuel Inertia switch to the fuel pump is Pink w/ Black stripe.
The other side of the fuel pump is black to ground #G104.
This is the fuel pump only, not the fuel level sender to the instrument cluster or the fuel tank pressure sensor.
