warning light [brake]
Old Jan 1, 2010 | 01:42 PM
bb45's Avatar
i have a 99 f105 4x4 4.6 the brake light one on the bash is stuck on im new to ford repair so b4 i waste i lot of time looking at all the wrong things was wondering if there are any tips the fluid is full the e/brake pedel seems ok lots of pads on front new shoes on rear any tips on how to test switches ie on the resivoir the ebrake is there a switch on the proportioning valve or any others you can think of thanks all from a ford newby BB
Old Jan 1, 2010 | 06:31 PM
bb45's Avatar
after a little more lookin todat i noticed that the warning light is not on when i first start the truck but it comes on after a few min of ideling ???? any help
Old Jan 1, 2010 | 06:42 PM
SSCULLY's Avatar
Did you try to pull the release, and pull up on the brake pedal ?
I sometimes catch my pant leg on the brake pedal and it clicks 1 notch and sets the light.
This is if you are sure the brake fluid is full.
BTW did you have recall 05S28 done ?
Old Jan 4, 2010 | 11:27 AM
bb45's Avatar
thanks scully wish it was that simple weve looked at all the easy stuff now im tryin to find someone who knows the more obscure stuff Ill have to see about the recall dont know a lot about the truck just started drivin it recently what is the recall for ?? tyvm BB
Old Jan 4, 2010 | 03:02 PM
SSCULLY's Avatar
The recall is for the leaking cruise control secondary safety switch.
This is the one where it can leak, and cause a high resistance load, igniting the brake fluid that has leaked out, igniting the whole truck.
Check the Ford site to see if you VIN still shows the recall as open, if it is, unplug the factory harness and zip tie it up, until you can get to a dealer ( Cruise won't work, but it will not light on fire either ).
Old Jan 10, 2010 | 05:01 PM
bb45's Avatar
thanks
might not be a big issue if this truck burnt lol would save me a lot of work still got the brake light problem now theres a fuel leak at the rail at the rear injector on the drivers side any ideas on how hard this is to fix
