Ground Wire Question
Old Dec 27, 2009 | 08:45 PM
derrick929's Avatar
Does the ground wire for an electronic component need to be the same size as the power wire? Or can it be smaller and still be adequate? For example if I was adding an in-line fuel pump, can you use a 10-12 gauge power wire and then a 14-16 gauge ground wire or does it need to be the same size as the power wire to keep it from overloading?
Old Dec 27, 2009 | 08:48 PM
shotgunz's Avatar
It's a DC series circuit and the ground will carry the same current as the positive. It needs to be the same size.
Old Dec 27, 2009 | 09:35 PM
derrick929's Avatar
Perfect! I was assuming it carried the same load but wanted to make sure.
Thanks!
