Battery losing charge after replacing alternator & battery
Old Dec 13, 2009 | 11:21 AM
kentaylor4's Avatar
Just replaced the battery and alternator in my '99 F150 4x4. Ran fine for a couple of days, then the battery light came on, and the next morning it started fine ran about 100' and died again. The evening befor when I pulled into the driveway I heard a loud pop and the truck died, but then it started right back up. Anyone have any suggestions or solutions?
Old Dec 13, 2009 | 11:44 AM
Camarothatcould's Avatar
Make sure your connections are good and clean... If you think something is draining the battery, some sort of short, put a multimeter on the battery, look at what it reads, than one by one, start pulling fuses... if the voltage jumps after you pull out a certain fuse, than trace whats circuited to that particular fuse you took out and check it out
Old Dec 14, 2009 | 11:31 PM
BlackFord123's Avatar
AHHHHHHH wish i got to earlier.... had the same problem your gona laugh if you got the same problem that i did..... on the passenger side you have a cover that your main electrical harness hides behind.... when you pull off that cover theres is a little fusebox that will be in that little cluster of crap.... open up that little fuse holder and check that fuse..... thats probably going to be your problem!!!!!!
