Headlight Problem
Old Dec 10, 2009 | 05:19 PM
LovetheTide's Avatar
Headlight Problem
My passenger side headlight won't come on anymore. I installed HID's and messed around with the bulbs for about 15 minutes only to realize they sent the wrong bulb and now the headlight won't work at all. I've tried a different (new) bulb and it still didn't work. So at this point I'm thinking it might be a fuse problem? All of the wiring looks fine to me.
Any ideas why it won't work or things I might try?
Old Dec 11, 2009 | 06:31 PM
Any idea's guys?
Does anyone have a diagram of what fuses I should check?
Old Dec 11, 2009 | 07:14 PM
SSCULLY's Avatar
It is on pages 241 & 242 in your owners manual
Fuse #23 : RH low beam headlamp
Fuse #25 : LH low beam headlamp
This is with the factory bulbs installed.
Old Dec 12, 2009 | 01:20 AM
Thanks for the help. It was a blown fuse.
Old Dec 12, 2009 | 10:08 PM
I thought that would fix my High beam problem but they still don't work. Well, when I flip for them to come on the left headlight cuts off and the right stays on but doesn't switch to the Hi mode. I looked in the manual and they don't use fuses but it's a "full ISO relay." How do I go about fixing or replacing this?
Old Dec 12, 2009 | 11:50 PM
SSCULLY's Avatar
Might want to check your owners manual on page 242, Fuse #35, high beams.
Is the problem you are having with the factory lamps, or the HID kit ?
If it is a HID kit, do you have a link to the install directions ?
Do you have the factory fog lamps ?
Old Dec 13, 2009 | 05:49 PM
That fixed the problem once again, thanks.
This all started when I was putting on my HID system and the lights they sent were the wrong one's so I'm believing that those lights caused all the problems, and now I'm just fixing them.
I don't have factory fogs.
