No brake lights
Old Dec 5, 2009 | 10:00 PM
hackyzac's Avatar
No brake lights
Ok, i have no brake lights.
Fuses, bulbs, relays and stoplight switch are all in working order....what else do i need to check?
Old Dec 5, 2009 | 10:31 PM
jgger's Avatar
Do you have turn signals and emergency flashers?
Maybe thr grounds?
Old Dec 5, 2009 | 10:33 PM
hackyzac's Avatar
flashers and turn signals both work, all my lights work except brake lights
this is a 2004 f150 btw
Old Dec 6, 2009 | 12:10 PM
SSCULLY's Avatar
Does the CHMSL work, or is it all 3 brake lamps that do not work ?
2004 SCab, is this the New body style, or the Heritage ( like the 99-03 ) ?
Old Dec 6, 2009 | 12:42 PM
hackyzac's Avatar
all three brake lights are out
It's the new body style super cab
Old Dec 6, 2009 | 02:26 PM
SSCULLY's Avatar
Might want to go back and check the fuse and the BPP ( Brake Pedal Position ) switch.
Not sure what relays you posted about with the stop lamp circuit, there are no relays in the circuit to be in working order.
How did you test the BPP ?
Old Dec 6, 2009 | 04:47 PM
hackyzac's Avatar
It did end up being the switch on the brake pedal
Thanks for the help guys
