I need an 09 power mirror wiring diagram / help
Old Nov 12, 2009 | 07:09 PM
04xltsc's Avatar
Smile I need an 09 power mirror wiring diagram / help
Im installing power / signal / heat mirrors in my 2009 FX4. The turn signals work but I need to make the heated function work. I know the truck is wired for it but Id like a diagram to help me figure out which wire I need to power up on the mirror to turn on the heater. I was gonna buy the new heater controls, but I may just use a separate switch. I cant see spending over 200 dollars on a new heater control just to get a defrost switch to activate the mirrors. Besides, I know on the older models you had to add a new fuse panel with a relay for the defrost. Does anyone know if that is the case with the 09's as well? Any help or insight would be appreciated. Thanks
Old Nov 12, 2009 | 07:17 PM
TascaFordParts's Avatar
Former Sponsor
In 09 Ford did away with the fuse block and decided to call it a "smart junction box" and all of the trucks have the same one (only one choice in the catalog) So it looks like either you can put in a new heater control or as a diy just wire in a switch and relay.
Old Nov 14, 2009 | 01:11 PM
04xltsc's Avatar
OK, thanks for the info. So if I would just add the new heater control would I also need a relay or is it already there? I believe the part number I need for the heater control is AL3Z-19980-B. Can you verify that and see if I need a relay? I would be more than happy to order from Tasca as a way to thank you for the help. Please advise. Thanks
Old Nov 14, 2009 | 01:14 PM
04xltsc's Avatar
Also, that part number wont come up on the Tasca web site.... FYI
