Auxillary Power Point Problem
Old Nov 12, 2009 | 10:09 AM
SteamJockey's Avatar
Have a 2006 XL w/Regular Cab. I just attempted to use the APP with a USB charger and note it doesn't appear to work while cigar lighter port does. Ignition was off. I'm assuming the fuze was blown but can't figure out which one. Manual has no entry for Auxillary Power Point. Well, at least I didn't see one that made sense to me. I read thru the archives and see references to 37, 39 or 41 for other years/models. I'll check them tonight.
Does anyone know which fuze for the 2006 Reg Cab?
TIA
Old Nov 12, 2009 | 01:08 PM
SSCULLY's Avatar
If you check the owners manual, the fuse is #39 Instrument Panel Power Point.
Old Nov 12, 2009 | 01:32 PM
Yeah, I did but, Instrument Panel Power Point didn't connect for me, I guess I was looking for Auxillary Power Point as that's what the manual called it. I assumed it would be called the same thing in the Fuse Table. My Bad. Thanks.
Old Nov 12, 2009 | 02:59 PM
SSCULLY's Avatar
They are named instrument panel power point and rear power point in the fuse, as there is more than 1 in the SCab and SCrew cab configurations.
