Odometer light went out...please help
my odometer/tripometer screen went out(07 f150 fx4)...on my way from work today I dimmed my cluster and as my screen dimmed it jus turned off and stayed off....could that bulb be the cause??? this should still be covered under warranty right????
The digital reading itself or the backlight for it is out ?
If you look close, can you read the display ?
If it is the bulb, I would guess no ( consumable items are not usually covered ), if it is the display, I would guess yes it is covered.
