Brakes cause Turn signal fuse to blow
Old Oct 31, 2009 | 02:39 PM
bdob's Avatar
I have a '01 Supercrew 4x4 that in the last three weeks has been blowing the 20amp fuse for the turn signals and flashers. I realized yesterday that it blows when the brake pedal is applied. I've checked or replaced related fuses,(none blown), and the tail/brake lights. Any advice would be appreciated.
bdob
Old Oct 31, 2009 | 06:19 PM
SSCULLY's Avatar
Is the fuse you are blowing CJB ( aka Central Junction Box, cab fuse panel ) Fuse # 13 ? ( Turn signal fuse is CJB Fuse #23, 10A ).
Confused by the description and the size crossing.
CJB Fuse # 13 feeds directly to the BPP ( Brake Pedal Position ) Switch.
after the BPP switch, this is on to the CHMSL, aftermarket CHMSL, the Trailer Tow stop lamp ( brake controller ) and back around through the MFS ( multifunction switch ) to feed the brake lamps if the MFS is not flashing one of the rear tail lamps ( no turn signals, or the side opposite the turn signal ).
If the turn signals work, I take a guess and say the MFS is OK, but this needs to be kept in mind after some diagnoses.
Some configuration questions
1. Do you can a cap or other that is using the aftermarket CHMSL ?
2. Do you have a brake controller installed ?
3. Do you have something like a line of fire installed ( or similar ) ?
4. Any other modifications ( LED CHMSL as an example ) ?
5. Did you have the recall done ?
With some background info, we can find which way to look.
Let us know
Old Nov 2, 2009 | 11:10 AM
bdob's Avatar
turn signal fuse blowing
Thanks for getting back to me.
The fuse that I have been blowing and replacing is in the cab and #13. I have not checked any under the hood. There is a brake controller that was there when we bought the truck. We had a cap installed and the inline fuses that I have seen are still OK. The turn signals and emergency flashers go out when the fuse blows.
I don't know about the recall.
I hope this helps. Thanks again.
bdob
Old Nov 2, 2009 | 01:58 PM
SSCULLY's Avatar
There is a recall for the cruise control
recall 05S28. Description: Speed Control Deactivation Switch.
You can check at the Ford owner site to see if it is scheduled ( should be ) and if it has been done.
Could be a short to the factory cap CHMSL, depends on the size fuse the cap used ( if it is 5 A or 15 A ).
You can disconnect the brake controller, to see if that is it.
Anything with LED CHMSL or tail lights, Line of fire aux light ?
Old Nov 3, 2009 | 02:29 PM
bdob's Avatar
I removed the brake controller and the associated under hood fuse. #13 in cab turns signal fuse blew again when the brake pedal was touched. I entered the vin at the ford site and it said no recall on that vin. What is the CHMSL, and where can I check it?
Thanks again
Old Nov 3, 2009 | 04:49 PM
SSCULLY's Avatar
Thanks again
Sorry, Center High Mount Stop Lamp ( 3rd brake light on the back of the cab and on the cap ).
