switched 12v source on 2001 lightning
Old Oct 8, 2009 | 08:34 PM
daveor2's Avatar
I am trying to install a satellite radio in a 2001 lightning. I have gone to the radio fuse in the fuse box only to find out it is not switched. i realize that a circuit provides continual power for the clock and memory at all times but there has to be a switched one somewhere. Does anyone have a suggestion as to a fuse location I can use?
Old Oct 8, 2009 | 10:06 PM
SSCULLY's Avatar
I assume the radio fuse you are talking about is CJB ( aka Central Junction Box, Cab fuse panel ) Fuse #1.
The radio fuse you want to use an add-a-fuse in is CJB Fuse # 8. This is the hot in run / accy position fuse that tuens the radio on and off with the key.
Old Oct 9, 2009 | 11:36 AM
daveor2's Avatar
Thank you for the suggestion, I will give it a try.
