f-150 starter
f-150 starter
hey guys.my 85' has a problem with the starter not shutting off.After i try to crank it it keeps going,I have to disconnect the battery for it to stop.I have installed a new ignition switch and relay,as well as a new starter and both cables.any help is great.Thanks
Did you change the correct relay/selonoid? Been I while since I seen an 85 but sounds like seloniod is sticking or maybe short in wires....... Check starter wires at starter, make sure they are positioned so that they are not hitting anything when you installed new starter too.
