Elec. System Beginner - Adding 2nd Battery
Old Aug 26, 2009 | 11:33 PM
mblouir's Avatar
Hey guys,
Sorry if this has been asked before but I wasn't sure of what terms to search for. I looked around but couldn't find anything too specific.
I'm clueless as to what I'll need to buy or do. I want to add a second battery so I can run my radio while I tailgate. Right now it doesn't last very long on the stock battery.
My question is what battery type do you guys recommend (deep-cycle?) and how would I go about wiring it up specifically for the radio? If you need specs on the system I'll get those asap.
Thanks for the help and again sorry if this has been asked before. If you guys have any recommendations for websites to read up on specific to this please post them.
Thanks!
edit: found these threads:
https://www.f150online.com/forums/20...r-battery.html (Inverter for the second battery? I want what this guy does--to keep the stock battery from dying and use the 2nd battery for the radio/accessories.)
https://www.f150online.com/forums/el...d-battery.html (Would I need to upgrade my alternator? I only want an extra battery to run the radio from. Would it be better to run two batteries in parallel?)
Old Aug 27, 2009 | 06:22 PM
Steve83's Avatar
Fuse the W/Pu wire from that diagram to your HVAC blower switch (or some other circuit) so it's hot only in RUN & ACC. Use 8-10ga wire between the battery (+) posts and a 30-40A Bosch/ISO relay with a matching fuse at EACH battery.
If you have some empty positions in your fuse block, read thru these captions:
