90 f150, No headlights, all other lights seem fine
Old Aug 21, 2009 | 02:16 PM
Novanut's Avatar
I apologize in advance if this has been answered a million times before but I'm new here and couldn't find the answer doing a forum search.
I recenlty bought a 1990 F150 4.9L AT LB 2WD that had no headlights. Since all the other lights worked, I guessed it was a headlight switch. After replacing that, I still have the exact same problem, no headlights. The tailights, all four blinker lights, the dash lights, interior lights etc all work fine.
I did also check the fusible links by the battery that run to the solenoid and they seem to be fine. also installed a new headlight bulb in case of the off chance that both filaments in both bulbs were bad.
Could it be a ground issue and if so where is the ground for both front headlights?
Is there a fuse or relay other then under the dash (that fuse is good)?
Could a bad floor mounted dimmer switch cause both high & low beam headlights to not work?
Any other ideas?
Thanks again in advance for your help!
JT
jtmi@comcast.net
Old Aug 21, 2009 | 07:54 PM
Steve83's Avatar
The grounds are on the inner fenders or core support near each headlight. There is no fuse for the headlights - the circuit breaker built into the switch is fed by a fusible link at the starter relay. Yes, the beam select switch could be the fault. Is it plugged in fully?
