Aux. Reverse lights
Old Aug 17, 2009 | 12:08 AM
05lifted50's Avatar
Aux. Reverse lights
Does anyone know the correct way to wire auxilary fog lights to turn on when i shift the truck into reverse? I just need to know which wire on the 7 pin trailer jack is for reverse. Btw-04 f150 fx4
Old Aug 17, 2009 | 08:56 AM
SSCULLY's Avatar
Here is the diagram from the trailer tow adapter install from Ford
Old Aug 17, 2009 | 10:01 AM
05lifted50's Avatar
Thanks a lot! Thats exactly what i needed!
Old Aug 17, 2009 | 03:10 PM
Steve83's Avatar
If the truck already has a Trailer Reverse Lights relay installed, you can tap directly into the wire for the 7-pin connector. If not, you should add a relay for your new lights.
Old Aug 18, 2009 | 09:48 PM
thejake1989's Avatar
i just installed mine and suggest you check out the technical articles for the one on adding reverse lights and run them to a switch it is very functional so they can be turned on whenever
