Oxidation cracked this part...not sure what it's for (pics.)
Old Mar 12, 2010 | 02:17 PM
ELVATO's Avatar
I see. Well, it's good to know that Tasca has them
Old Mar 13, 2010 | 10:03 PM
sam1947's Avatar
Tasca DOES NOT have them ! Tried to order one a week ago, order was put on hold. Got a message saying the part IS on national backorder, however they could get one from another dealer, but the 'to my door' price would be quite a bit more $$ due to a special order and shipping cost. Bottom line it seams is that Tasca does not have any in stock, but can get you out of a pinch for more $$.
Old Mar 18, 2010 | 11:44 AM
clambelly's Avatar
clambelly
Senior Member Join Date: Jan 2008
Vehicle: 2005 ford f150 fx4
Clean module and maintain with CRC Heavy Duty Corrosion Inhibitor.
I live in my own world, but it's alright everyone knows me here.
clambelly
View Public Profile
Send a private message to clambelly
Send email to clambelly
Find all posts by clambelly
Add clambelly to Your Contacts
Today, 03:54 AM
code58
Senior Member Join Date: Nov 2006
Vehicle: 2004 Ford F-150
Quote:
I have a better idea. Have you ever seen the "Liquid Electrical Tape" in a spray can? mask off the port where you plug the electrical lead into it (or better yet, plug it in first) and then seal it off well with a couple or three good coats of that stuff. It's rubberized and would do a permanent job of sealing the whole thing, including plug, off from the elements even in salt country.
code58
View Public Profile
Send a private message to code58
Send email to code58
Find all posts by code58
Add code58 to Your Contacts
Today, 09:36 AM
clambelly
Better than that kid's stuff from homedope or lowes stores get some 3M- Scotchkote. I use the CRC on the backing plates of my boat trailer and it does a good job of keeping the Atlantic Ocean's salt at bay.
Old Mar 18, 2010 | 01:19 PM
SSCULLY's Avatar
If the reason for the aluminum metal base is to act as a heat sink, coating the module in liquid electrical tape is a bad idea.
So far there is only speculation on this.
Just something to think about, prior to coating the unit top and bottom.
Old Mar 19, 2010 | 09:36 AM
MMasz's Avatar
After you get a replacement or for anyone with a newer vehicle and want to protect certain parts in the engine compartment from corroding, try this stuff.
http://www.sonus-usa.com/son-720.html
It's an acrylic wax which seals these types of components from corrosion. I live on a barrier island and the salt spray gets on everything. You need to clean under the hood as much as you do the exterior.
Old Mar 19, 2010 | 05:02 PM
Finley's Avatar
Thoughts on this then, our truck broke down in the middle of a raging rain storm a couple weeks ago in NH. Had it towed, $150. Garage said it was the fuel pump $620. In replacing the fuel pump, the fuse panel fried (mechanic error and they replaced it), then the mechanic says the modulator is bad. Went through the hassels of obtaining it and did find it from the OEM on ebay after two weeks of arguing for Ford in Detroit about the backorder and paid the $189 for that. Get the truck back and the check engine light is on. And the very next morning the truck won't start. Jump it and take to the garage (different one) and they said a couple of the cells are bad in the battery - buy a new one $90. And the check engine light is still on. Go back to initial garage, he says it has error 0451 (emissions). The overall component needs replaced or it won't pass inspection and that part alone is $520! This truck is a 04 with 79,000. Could the modulator have been what caused all the other issues or could the mechanic who fried the fuse panel have caused it? We are going broke on this truck and about to drive into the flooded river across the street! Any insight? Please!
Old Mar 27, 2010 | 08:52 PM
bankrpt's Avatar
Originally Posted by sam1947
This is getting to be quite a problem for us, and yes, it is on national backorder. You did the right thing by getting it off the frame rail with washers, but, I would not put it in a plastic bag. Moisture will have nowhere to go and you will have an internal short inside. Some of these have wiped out fuel pumps and PCM's when they go bad. Bottom Line: Plastic bag = Bad Idea !! CONDENSATION !!
put a few of them silica packs in threre lol that will suck up the moisture
Old Mar 29, 2010 | 08:29 AM
top2002's Avatar
I have an 05 and had to relace mine about two years ago. I had a hole develope on the underside of the module. This really should be a recall item.
Old Mar 29, 2010 | 08:38 AM
MGDfan's Avatar
Hello.
No - this is a heat-producing component - it needs to breathe and radiate.
NO encapsulation of any sort is advisable.
I am working on a relocation project for this item to mitigate the original design failure modes.
MGD v5.0
Old Mar 29, 2010 | 08:40 AM
bankrpt's Avatar
I was being a Jack a$$ LOL
Old Mar 29, 2010 | 08:47 AM
MGDfan's Avatar
Ah.. silly me
Carry on! It's my normal Modus Operandi
MGD v5.0
Old Apr 2, 2010 | 08:28 PM
AZFX4's Avatar
I would still get rid of the bag on there. Electrical parts need to breathe.
Old Apr 3, 2010 | 04:25 AM
code58's Avatar
Sounds like the original mechanic should go back to his day job at McDonalds. Was there anything wrong with the fuel pump that they diagnosed as bad and charged you $620. to replace? Sounds like quite a bit of incompetency from the start. What are the chances that your fuel pump and module both went out at the same time. How did he fry the fuse panel? I wouldn't think there would be juice to the pump while he was replacing it, so the fuse panel shouldn't be affected. Someone trying to learn on your truck and your dollar, and not doing a very good job of learning. Want'a be mechanics! Sheeesh!
Old Apr 16, 2011 | 02:36 PM
DKasco418's Avatar
Plastic likes to attract condensation.
Old Apr 18, 2011 | 06:35 AM
mjb1032's Avatar
Wow...it's been over a year since this thread showed up in my e-mail...
(way to raise-the-dead DKasco)
If I get a chance, next Saturday I'll check that part and see what shape it's in.
....It's a good idea to check the spares' pressure once in a while too.
