Trailer running lights
Old Jul 25, 2009 | 05:27 PM
DaMoose81's Avatar
So i did a pretty extensive search and came up short handed. Ive got a 2006 F-150 with the stock tow package. Ive got a four pin and a 7 pin hook up in the back. Ive towed at least 4 trailers and every time, no running lights. The turn signals and the brake lights always work. Ive tried using the 4 and the 7 and its the same.
Anyone know what fuses i should try swapping out first? I read the owners manual fuses and there doesnt seem to be one with "running lights" in the description.
Thanks in advance
Old Jul 25, 2009 | 06:37 PM
SSCULLY's Avatar
Correct name would be parking lamps ( abbrev parklamp in the manual ) page 241, Fuse # 10.
Old Jul 26, 2009 | 12:10 AM
DaMoose81's Avatar
Thanks man!
So change the fuse, if that dont work, change the two relays, and if they dont work, check the wiring
Old Jul 26, 2009 | 11:58 AM
Wade06XLT's Avatar
Just did this Friday,,think I replaced nmbr 10, and 36. I now have running lights, left brake and left turn signal. Used the link that contains the online manual for our trucks. Let me see if I can find it. didn't go hunting for the other fuse becasue I wanted to get on the water BAD.
Old Jul 26, 2009 | 12:00 PM
Wade06XLT's Avatar
Here ya go: https://www.fleet.ford.com/maintenan...ls/default.asp
Old Jul 26, 2009 | 02:34 PM
SSCULLY's Avatar
Originally Posted by DaMoose81
Thanks man!
So change the fuse, if that don't work, change the two relays, and if they dont work, check the wiring
It would just be the one relay, if needed.
When you replaced the fuse, the next step is to meter for power in the relay socket, if you do not have parking lamps. This will step through the diagnostic steps to know if you need to bench test the relay.
