Will not shift
Old Jul 13, 2009 | 06:08 PM
68halfcab's Avatar
Will not shift
I have a 96 f150 that will not shift out of park, the abs light flashes upon start up then stays on, help
Old Jul 14, 2009 | 12:16 AM
4play2008's Avatar
check the brake fluid and all the fuses
Old Jul 14, 2009 | 07:07 AM
SSCULLY's Avatar
Won't shift out of park at all, or while running ?
If you turn the truck to the accy position ( without starting ), press and hold the brake pedal, can you shift to neutral, then start the truck ?
Get some help from someone to make sure your brake lights work ( including the 3rd brake light ).
Let us know what you find out.
Old Jul 28, 2009 | 06:41 PM
68halfcab's Avatar
found out the multi switch (turn signal, 4-ways,ect) went out, that took fuses and kept the truck from shifting out of park. the accy position worked thanks
