cant roll my window back up!!!!!!
Old Jun 27, 2009 | 02:16 PM
f150fella08's Avatar
dude! i guess i got a short or something in the wires because i got home and rolled my windows up and the passanger side went up but the driver side isnt moving so i got my daddys switch out of his truck and tried to roll it up so i wouldnt have to worry about rain or anything and it still didnt go up i have a 2002 btw
Old Jun 27, 2009 | 02:31 PM
K-Mac Attack's Avatar
Can you hear anything when you press the button. I would bet the motor in the window went bad. Otherwise the cable in there could have broke.
Old Jun 27, 2009 | 02:44 PM
jetech00001's Avatar
well i think if all the rest work and you swapped switches its a good chance its the motor i would use a vom and see if you are getting power to the motor if you are good chance its the motor and if not i would start chasing wires good luck
Old Jun 27, 2009 | 02:52 PM
checked the wires and they are all good, so i looked at the motor and it looks like a PITA because the window is down, any suggestions on how to swap motors or get the window up??
Old Jun 27, 2009 | 04:14 PM
the last time i changed a window motor was a few years ago take off door panel and see how its mounted mine had rivets holding it in place i drilled them out and used nuts and bolts to secure it. the hardest part for me was getting the door panel off i hate those clips that hold it on. the new motor will have instructions i picked the motor up at auto zone good luck
Old Jun 27, 2009 | 08:30 PM
SSCULLY's Avatar
Can be common, my dad's F150 had this happen not too long ago.
When you press on the button, you can hear the driver's side relay clicking ?
Here is a thread on removing the motor, and the tire thump for testing.
https://www.f150online.com/forums/el...dow-motor.html
Old Jun 27, 2009 | 09:13 PM
Jza's Avatar
Jza
i gotta push my switch a few times to get the drivers side up.
worst part is they replaced the switch under warranty back in 2006...
Old Jun 28, 2009 | 01:27 PM
SSCULLY's Avatar
That is what happened to my '06, and it was dirty switch contacts.
Jack has some nice pictures in his wirte up in the Tech Articles / How-To forum
https://www.f150online.com/forums/ar...-switches.html
Those are dirt easy to clean, have a read, and a go at it.
I replaced my switch when it starting acting up some time back, and after that is when I found you can clean them real easy. Save yourself 60.00 by cleaning the contacts.
The OP has a '02, where the motor problem is more common ( but not 100% the problem, just the common problem )
Old Jun 29, 2009 | 12:41 AM
no when i hit the switch i cant hear anything clicking or humming
Old Jun 29, 2009 | 11:16 PM
well, this morning when i got to my truck, i peeled off the trashbag covering my window, and cleaned up some of the tape residue, then i pluged in the switch to roll down the passenger side window and i was like hey what that heck ill give it a try and rolled up my driver side window, i have no idea what it was but it works now
