92 f150 Dead in driveway
Old May 30, 2009 | 06:49 PM
drdk4330's Avatar
I am lost here maybe someone can point in a new direction
92 f150
Shut down in driveway
Battery good
Fuel shut off not activated
Absolutely NOTHING is working not even Horn
Power is good to Under hood box except for no power to one fuse
Any Ideas
Old May 31, 2009 | 04:55 PM
Steve83's Avatar
What's the one fuse? Have you looked in your owner's manual? Do the headlights work? Remove, clean, & tighten both battery clamps. If that doesn't fix it, do all the other terminals on the 2 heavy battery wires.
Old Jun 1, 2009 | 12:21 AM
BlueBobbyBird's Avatar
Originally Posted by drdk4330
....Absolutely NOTHING is working ....
No dome light?
No idiot lights on dash with key on?
When you checked the fuses, did any of them have power, or did you check them visually?
If you have absolutely no power... Did the '92s have a fusible link from the battery?
Zeevert
Old Jun 1, 2009 | 06:57 AM
drdk4330's Avatar
Checked posts all are good
Check fusible link to main box good
No Idiot lights,horn headlights,dome light
battery could be better but still good 12.6 V
Old Jun 1, 2009 | 06:59 AM
drdk4330's Avatar
The one fuse is #16 maxi fuse
It must be where the problem is
There is only 10 or so volts on it,I am having a hard time tracking those wires down
Old Jun 1, 2009 | 11:26 AM
Steve83's Avatar
Checked posts...
If you're not gonna follow our advice, why ask for it?
No, fuse 16 isn't causing this.
