Auxiliary Switches
Old May 22, 2009 | 03:46 PM
kankles747's Avatar
Unhappy Auxiliary Switches
i have installed a couple of aux switches in my f150 but am running out of ideas of what to connect to them. can anyone help and put there 2 cents in. i got 4 only 1 is connected to fog lights i have 3 empty
Old May 22, 2009 | 03:55 PM
NoLongerJeepin's Avatar
Reverse lights, fuel pump cut off, CB radio, small inverter, basically anything electrical?
Old May 22, 2009 | 03:58 PM
dsq3973's Avatar
I have the uppfitter switches in my SD and here is what I have mine hooked up to.
1. Whelen Hide Away strobes
2. Grote amber mini light bar
3. Recon LED bed lights
4. PTO High Idle (Diesel only)
Old May 22, 2009 | 04:07 PM
kankles747's Avatar
thanks, got a question for dsq3973 how did you run the bed lights wiring into the cab for your aux switch
Old May 22, 2009 | 04:11 PM
dsq3973's Avatar
I ran it along the frame rail to the engine compartment and I have a large gromet that is just above the fuse block where the terminated ends are for the wires for the upfitter switches are in my truck. This is on the Super Duty so I dont know if there is a gromet there on your truck or not.
Old May 22, 2009 | 04:18 PM
kankles747's Avatar
gotcha thanks again this is gonna be my next project
Old May 22, 2009 | 06:38 PM
jrfonte's Avatar
what wire did you connect to make it high idle? does it work on 06 6.0's?
Old May 23, 2009 | 12:53 PM
Steve83's Avatar
5. Courtesy light kill
6. Cigar lighter/powerpoint control
7. Self-destruct
8. Passenger eject
