radio,power windows and windshield wipers broken?
Old May 9, 2009 | 04:15 PM
jdaphotog's Avatar
I have a 2001 f150, And my winshield wipers, radio, power windows, cruise control and air conditoning only work when the key is in the "Acc" position. as soon as i turn the car on, they all stop working. Any ideas on what my problem is? any help is greatfully apreciated.
Thanks in advance
Joe
Old May 9, 2009 | 10:13 PM
torkum's Avatar
Check under the dash on the driver side to see if the windshield has been leaking on the GEM behind the fuse block. If no leak it could be something with ignition switch.
Old Jun 7, 2009 | 03:24 PM
Conceptkid's Avatar
Im having the exact same problem, but this all happened after I took my Multi function switch out to fix my tail lights, Im def thinking it has something to do with the ingnition power since all of the accessories dont turn on that would startup with the ignition, **** its frutstrating
Old Jun 7, 2009 | 07:56 PM
Conceptkid's Avatar
Alright, figured it out. It was a fuse under the hood that was in the wrong spot, somebody other than me was helping me and was taking fuses out and inspecting them and put it back in the wrong spot. It was one of those small square oldschool looking fuses
