2001 f250
Old Apr 29, 2009 | 01:52 AM
DeeF150's Avatar
2001 f250
My son just bought this F250, when I turn off ignition and take the key out, the radio stays on, the heater blower still works and the door chime comes on when I open it, a friend of mine has a 97 F150 with the same problem but his comes and goes, can anyone help?
Old Apr 29, 2009 | 09:12 AM
SSCULLY's Avatar
I am taking a SWAG with these 2 items
1. Windshield leak like the F-150 had an issue with ( have not confirmed if the GEM is on the back of the cab fuse panel, and if this even could get wet )
- It looks to be a similar layout with the accy delay ??
2. Ign cylinder problem not shutting off the hot in run position circuits
- Does anything else work like the power windows ?
The list sounds like it could be both, but I would lean towards the ign cylinder at the moment.
Do you have a bone yard around you can get an ign cylinder at cheap to try a quick test ?
