Intermittent Odometer - A Repair
Old Mar 16, 2008 | 05:47 PM
  #121
jadams's Avatar
has anyone attempted to fix this problem in an 04+ new body style??? is it the same procedure? how do i find a manual for my 04 to get the cluster out?
Old Mar 20, 2008 | 08:23 PM
  #122
paulhut's Avatar
Thanks for the great post!
I have a 1999 F150XLT and this fix worked great!
Thanks!
Old Apr 17, 2008 | 09:11 AM
  #123
Kenjohn1217's Avatar
Question Does this apply to non LED odometers?
I have a 1997 Ford F-150 and the odometer stopped turning around 98,000 miles. I believe that these mechanical odometers are driven electronically in the same manner as the LED type. Does anyone know if this the case? Thanks in advance. I'm new here.
Old Apr 18, 2008 | 04:44 PM
  #124
brozell7's Avatar
Smile Thank You!!!
Thank you for this post! My odometer was driving me batty. I followed your inst. and was able to fix!
Thanks!!
Old Apr 24, 2008 | 07:39 PM
  #125
mrgrizleebear's Avatar
thanks greg
i used your instructions to fix the led odometer on my 2000, works just fine now. thanks greg for this money saving info. doug
Old May 4, 2008 | 10:15 PM
  #126
cgirtman's Avatar
Question
I would like a 'how-to' on the 2004+ model trucks. My 2005 truck is doing this and I've pulled the instrument panel out but it's entirely different. I did my best to look for broken solder joints but couldn't find any. Any help would be greatly appreciated!
Old May 7, 2008 | 11:23 PM
  #127
Old_Red_Truck's Avatar
Odometer Fix
Just completed the odometer fix procedure and it looks like I'm back in business. The damn thing has been blinking on and off ever since I bought the truck 3.5 years ago. I thought there should be a way to fix it, but had no idea that this would be it. I am greatful to this forum and to the original member who posted the information and pictoral on how to do this. Thanks, HS
Old May 12, 2008 | 02:43 PM
  #128
damuniz's Avatar
Thumbs up Fixed my 99's Odometer this weekend.
It's been several years since I visited this site. I first joined sometime after I first bought my truck in 1999.
I would periodically browse the forums especially when I was on night shift. Then I moved to days and visited less often.
I came back recently to search for info on the P1151 O2 sensor code and found this thread on how to fix the broken odometer. I had just gone through state inspection and along with a couple of other minor problems they were going to fail it for the OD. I decided I had nothing to lose by trying the fix myself. Worse case I'd have to look for a used cluster on ebay.
I'm happy to say it looks like I fixed it. Removed the cluster and touched all the solder joints on the pins for the OD display with a hot iron. Put it all back together and 2 days later it is still working so I'm confident it is fixed.
Thanks to Greg for posting this repair.
Old May 26, 2008 | 10:38 PM
  #129
Wildpilot's Avatar
Your brilliant greg
just fixed my 2000 f-150 today, odometer has been intermittent for a year now,... thanks
Old Jun 7, 2008 | 12:53 AM
  #130
jeffreygeorge's Avatar
Thank you Greg. After all these years you are still helping people save big dollars. I fixed my 2000 F150 Odometer tonight...after 4 years of putting it off.
Old Jun 22, 2008 | 07:34 AM
  #131
derek7871's Avatar
Light Bulbs
I have my cluster out now and a friend soldered the pins for me. I'm waiting to put it back in so I can replace all the light bulbs on the cluster. Might as well replace them now while it's out.
Old Jul 4, 2008 | 11:00 PM
  #132
roadkillguam's Avatar
Registered User
1999 F150
I did the fix today on my 99. Worked great! 160k miles and still runs great.
Old Jul 5, 2008 | 02:47 AM
  #133
temp1's Avatar
I have been annoyed by the disappearing odometer for about a year now. I suppose its time to bite the bullet.
I finally got the instrument panel out, what a PITA. I see a little gray part fell off that looks like it belongs on the trip handle.
My eyes are not so good but it looks like the other terminals are a little short of solder.
I installed the cluster back in my truck. I had a headache when I woke up this morning before I started.
I have a slightly larger headache after the Cluster was installed back in the truck and I found this still on my dining room table.
If I have to take it back apart again I am going to look for LED bulbs to put in the cluster. Arrrrrghh!
Er, excuse me Mr. Jones but could you bring your truck back in for service. I discovered a TSB bulletin that provides an upgrade to your instrument cluster that should have been installed when we worked on the instrument cluster on your truck. This will be at no charge to you Mr. Jones. LOL
Old Jul 6, 2008 | 09:48 PM
  #134
temp1's Avatar
I finally put the back of the instrument cluster back on. I took some pictures this time.
I have not read all through this thread but I will post a few pictures with some tips.
I would suggest having a tool with a flexible shaft like this one.
This trim is removed first. It can be pulled off by hand by getting your fingers underneath it on both sides and pulling it towards you.
Old Jul 6, 2008 | 09:53 PM
  #135
temp1's Avatar
I turned the headlight switch to the fog light position and pulled it out. I then gave the switch a good hard tug to pull it off. This worked for me but I do not know if it is the proper way to do it so only do this if you cannot find the proper way to remove it.
The Headlight switch assembly has a latch that keeps it attached. I inserted a thin standard screwdriver and pushed the latch to the right as shown in the following photo. ( in the direction of the arrow ) The assembly will pull right out when the latch is properly dis-engaged. You can feel the spring pull against the screwdriver when you are sliding the screwdriver against the latch.
Do not pry behind the assembly like I did the first time or you will damage your trim.
