Help please
Old Apr 2, 2009 | 07:11 PM
jb526's Avatar
Help please
I disconnected my battery and installed a new Magnaflow exhaust. When I hooked the battery back up, my driver's side power seat no longer works. I have checked the fuse and it appears fine. I also swapped it out with another fuse, butit still did not work. Any thoughts?
Old Apr 2, 2009 | 11:27 PM
SSCULLY's Avatar
The Driver's side switch actually has 2 fuses to it.
F3 7.5 A and F109 30A
The set is a memory seat, and different then the passenger's seat.
The passenger's seat, the switch operates the motors directly.
The Driver's seat the switch signals the driver's seat module ( F3 ), and the driver's seat module operates the motors ( F109 ).
So if either fuse is out, the seat will not move.
Take a look at F3, check both sides of the fuse with a meter or test light, on the exposed end pins.
Let us know what you find.
Old Apr 3, 2009 | 05:51 AM
jb526's Avatar
Thanks, I'll check on the second fuse today.
Old Apr 3, 2009 | 03:24 PM
jb526's Avatar
Both fuses are fine. I replaced them anyway, but the seat still does not function. Any other thoughts?
Old Apr 3, 2009 | 04:28 PM
SSCULLY's Avatar
Time to check for power at the driver's seat module.
There are 3 connectors on the Driver's seat module.
C341A is a 24 pin ( 2 rows of 12 ) gray connector
C341B is a 2 pin Gray connector
C341C is a 10 pin ( 2 rows of 5 ) gray connector.
you are looking for the 2 pin connector
The wires are
pin 1 - Dark Green = circuit from F109
pin 2 - black = Ground
The other is the C341C connector
Pin 1 Orange w/ light green stripe wire = circuit from F3
Use pin #2 as ground and test for + DC V on both connectors.
These are hot at all times, so key position is not important.
