Wiring for power seat
Old Mar 6, 2009 | 10:50 PM
Dogzilla's Avatar
I'm thinking of getting a set of seats that has a power seat. The current seats in my 01 are not power. Does anybody know how big a deal it is to get power to the seat? Is there a simple fix?
Old Mar 7, 2009 | 12:15 PM
SSCULLY's Avatar
If you have a XLT, the wiring might already be in the floor by the seat area.
Might not be there, if not no big deal.
The circuit is Battery Junction Box ( aka BJB or engine compartment fuse panel ) Fuse # 112 ( 30 A ) and is dark green.
The power seat should come with the power seat control switch on the side already.
If the switch is good, on the connector C311, you have 2 wires to add
pin #1 black to ground
pin #7 dark green, to hot at all times ( BJB Fuse #112 )
That is it, the seat should work. Pin #1 and Pin #7 should ( might depending on the deinstall ) have a connector end on them, which is connector C305.
This is assuming they are power only, no heated seat module.
