Side View Mirrors with signal
Old Feb 22, 2009 | 07:14 PM
ad2tude's Avatar
Hey guys, anyone know if the side view mirrors with the signal will work if installed on a Screw that didn't have the signal option mirrors?
Old Feb 22, 2009 | 07:29 PM
SSCULLY's Avatar
Yes they will, just depends on how much wiring you will need to add.
Take a look at www.muthco.com and download the directions for your MY.
I installed these on my 2001 SCrew XLT, and the wiring was already in the door.
Same should go for the factory mirror heads, or if you are just replacing the glamor caps, and modifying the mirror head to make them work.
https://www.f150online.com/forums/ot...or-covers.html
Old Feb 22, 2009 | 07:38 PM
ad2tude's Avatar
Thanks Sscully, I work for a body shop and have access to used parts. I've always wanted the signal option, and my XLT didn't come with them. I'll now give it a shot.
Old Feb 22, 2009 | 11:27 PM
SSCULLY's Avatar
Keep an eye on the SCrew has different mirrors then the SCab, and Std cab trucks.
The size of the doors on the '03 and older SCrews are different and the sail panel ( where the mirror bolts to the truck ) is different then the other ones.
Not sure about the Glamor caps, I think they are the same on all ( just the mounting is different on the Screw ).
