bi-xenon highbeam help
Old Feb 18, 2009 | 11:40 PM
amiexploited's Avatar
Angry bi-xenon highbeam help
i just put in bi xenon hids "xentec's"
i plugged everythin in, and my driving lights are hi beams and my hi beams are driving...
i searched and i only found where hi beams and fogs became a problem..not mine.
and i read in one post that i switch the wires?? what wires???????
and i tried switchin bulbs, and tried turning them around, but they only fit one way......
thanks
(i have an 01)
Old Feb 20, 2009 | 01:53 AM
bumps....
please someone help.
i read in another post that the bulb (it only fits one way tho!) is upside down, or the wiring harness for hi's is switched.
if thats the case, how can i switch them???
the wire connectors only plug into to its own specific plug.,.
thanks!
Old Feb 20, 2009 | 07:55 PM
mtylerb's Avatar
To start, you know that you are blinding everyone on the road, right? I tried to use a PnP kit in my F150, and the glare is terrible. I am going to be retrofitting my truck with an OEM Acura TL projector and putting the proper bulbs into them so that the cut off saves everyone's eyes.
You might want to check out HIDPLANET for more information on retrofitting your truck with a true legal (well, mostly) HID system.
Old Feb 21, 2009 | 12:02 AM
well i got aftermarket black harley style headlights with the shell over the bulbs..
their aimed down, and i did a couple of tests, and the glare isnt that bad, or present really...
so help with my question,
thanks
Old Feb 21, 2009 | 12:12 AM
Screw-Me-05's Avatar
Is there a diode on your kit? if so try turning them around and see what happens. It looks like this is mostly a problem with BiXenon kits but a 2 second fix. hope this helps
Old Feb 21, 2009 | 12:44 AM
I dont think theres is a diode (from lookin at pics of diodes...didn't really know what it was)
but all the connectors can be connected one way, cuz theres a clip that has to snap.
and same with the bulbs, they only fit one way in the housing....
Old Feb 21, 2009 | 08:13 AM
SSCULLY's Avatar
Are there directions online for the kit, or can you scan and post your directions ?
A quick test ( to see if the ground location for the fog lamps is causing your problem ) is to pull the fog lamp relay, and see if you still have the problem.
