Trying to find wire connector pieces.....
Old Feb 11, 2009 | 02:04 AM
mattd17's Avatar
Hi all, im trying to find some pieces for certain wire connectors. I am looking for the square metal wire ends that push and snap into place in the wiring connectors for the radio head unit, and also for the steering wheel controller connector at the clock spring in an 06 f150 screw. For the radio pieces, i need the smaller of the 2 sizes.....
where can i find these parts? dealer possibly? are they available seperately or only as a whole connector?
the reason im doing this is that im trying to hook up the steering wheel controls in my truck which did not come stock with them.
Thanks !
Old Feb 11, 2009 | 08:34 AM
SSCULLY's Avatar
If you are only looking for the pins for the connector, then use the motorcraft pigtail guides to find the same type
http://www.motorcraft.com/products.do?item=23
File save as :
http://www.motorcraft.com/pdf/Pigtai...onKit_1of2.pdf
http://www.motorcraft.com/pdf/Pigtai...onKit_2of2.pdf
If you search on audio in the PDF, you might find a few connectors, else troll the guides to find the correct one.
Old Feb 11, 2009 | 09:32 PM
mattd17's Avatar
ok, heres an update...... i found some at my local dealer.....
BUT.... all it is is a female spade connection crimped to about a 4" pigtail.... and can you believe that they wanted 14.00 each ?? !! my jaw hit the floor.
Old Feb 12, 2009 | 10:19 AM
SSCULLY's Avatar
Drop Keith an email at www.southwestford.com, and ask him.
Also, there is another online dealer in WA, who might get the parts to you quicker, and he is a site sponsor
www.thinkpartsguy.com ( F150partsguy.com ).
He is in Bremerton, WA.
The only other option I can think of, is a bone yard. Any '04 + MY truck should do the trick. Cut the whole head off, as far as you can reach back in the dash, and once you get home, release the pins and reuse them ??
Last edited by SSCULLY; Feb 12, 2009 at 10:40 AM. Reason: correct URL, still having typing issues this month
