High Output Alternator???
Old Jan 25, 2009 | 01:17 PM
2me2's Avatar
Can anyone point me in the right direction on where to buy high output alternator for my 2005 ford f150 xlt 5.4??? Thanks
Old Jan 26, 2009 | 09:29 PM
Scuba Sam's Avatar
Check Summit Racing. I was looking at a 200 amp for my 98 Expedition and there was more.
Old Feb 9, 2009 | 09:47 AM
basstamer's Avatar
Try www.mechman.com or check out www.stevemeadedesign.com for Hi output alt.
Old Feb 10, 2009 | 11:16 AM
F150man21's Avatar
from what ive heard iraggi alternators are pretty good there only sold on ebay though
http://stores.ebay.com/Iraggi-Altern...nd-Electronics
Old Feb 13, 2009 | 11:38 AM
Black $ Chrome's Avatar
not what you want to hear but theres not really any piont in putting in a 200 amp alternator the 130 amp factory one it fine unless your running 4 600volt spot lights just run a second battery on the drivers side you can fit one
Old Feb 13, 2009 | 11:45 AM
travis08's Avatar
excessive amperage i have a 300 amp alternator from them
Old Feb 13, 2009 | 02:42 PM
SSCULLY's Avatar
Originally Posted by Black $ Chrome
not what you want to hear but there's not really any point in putting in a 200 amp alternator the 130 amp factory one it fine unless your running 4 600volt spot lights just run a second battery on the drivers side you can fit one
Well, I am not one to tell someone not to do something to their truck, unless it is going to release the magic smoke.
Look at it this way, he might have a high AMP requirement at low RPM, or idle.
The factory alternator is not going to put out anywhere close to 130 A at low RPM / idle.
The cost of using the correct size alternator for his application is going to be covered by the additional costs of ~ 3 battery changes, and it a long term solution, rather then a band aid solution. The heavy draw down, and charging of a 2 battery system ( in what his application is ) could put undue strain on the factory alternator, and cause premature failure.
Just some points to why he maybe looking at a high output alternator, vs a 2 battery system ( which he did not ask for ). You have a valid solution to a problem, but it might not be his problem.
Old Feb 16, 2009 | 09:10 AM
2me2's Avatar
Thanks guys for all the help. I found one here http://www.db-starter-alternator.com
