Trailer lights backup
Old Jan 23, 2009 | 10:27 PM
FALCON50EX's Avatar
I have a F-150 2008 that I would like to have some auxiliary backup lights on my trailer. The 7 pin has a place for this but it takes a brake box installation to make the 7 pin hot. There is a pig tail and relay that came with the truck. The pig tail should connect to the brake box and a 6 way gray wire connector.
Do I need to connect the brake box just to get backup lights
Old Jan 23, 2009 | 10:40 PM
SSCULLY's Avatar
The trailer tow reversing circuit should be active from the factory, don't think that was a relay or fuse to add like the '00-'03s.
Watch the load limit specified in directions.
Old Jan 24, 2009 | 11:29 AM
FALCON50EX's Avatar
Thanks i am going to put a tester on it now. I still will need and extra power outlet.
Old Jan 24, 2009 | 12:01 PM
SSCULLY's Avatar
I Went and read the sticky at the top of the towing and hauling forum
https://www.f150online.com/forums/to...locations.html
The only relay I added to my 2006 is the battery charge relay.
Should work fine.
