Fuse Box
Old Jan 13, 2009 | 07:35 PM
150Lariat2000's Avatar
Fuse Box
Hello Everyone... Problem with the fuse box and the heated mirror. The other day I removed the wrong fuse and went to put it back in and the fuse went in tight. I pushed it and now the fuse is loose and the heated mirrors won't work. It seems that I pushed the holder out on one side of the fuse box. How can I fix this??? Or what can I do.....
Old Jan 14, 2009 | 07:21 AM
Any ideas anyone???
Old Jan 14, 2009 | 09:15 PM
Fifty150's Avatar
Start all over with a brand new fuse?
Old Jan 14, 2009 | 10:11 PM
momalle1's Avatar
You must have pushed it pretty hard. Unbolt the fuse panel, push the connector back in and install the fuse while holding the connector from the back as you probably broke the retaining clip.
Old Jan 16, 2009 | 07:29 PM
Well it is at Ford... I am suppose to get it back Monday..... I was told that behind the fuse box was melted because something was shorted out and burnt up. I will fill you all in when I get my truck back Monday... They have to put a new fuse box it...
Old Jan 31, 2009 | 09:16 AM
dman66's Avatar
fuse box
how did the fuse box install come out ? I believe I have to remove mine for dash illumination issues.
