cluster swap
Old Jan 5, 2009 | 05:40 PM
03REPHARLEY's Avatar
cluster swap
i recently replaced my old cluster with a harley davidson cluster and my mph arent accurate, is their a way that can be fixed.
Old Jan 5, 2009 | 06:07 PM
4play2008's Avatar
probably have to take it to the dealer to get them to reflash your pcm.
Old Jan 5, 2009 | 08:47 PM
phil6608's Avatar
Most likely,,your MPHs is off because of your big wheels!
I have 2 different tunes to correct my speedo.1 for when I'm running my stock 16"s and 1 for when I'm running my 23"s
You can fix it with custom tuning.
Phil
Old Jan 6, 2009 | 04:14 PM
i will go by the dealer this weekend see what they tell me
Old Jan 6, 2009 | 04:19 PM
Phil
i trade my 24's for some harley davidson 20's and still my mph are off
Old Jan 9, 2009 | 07:35 AM
phil6608's Avatar
Hey,
let me know what all the dealer tells ya.
I'm getting ready to put a Lightning cluster in my truck and could use any info.
Phil
Old Jan 9, 2009 | 11:16 AM
SSCULLY's Avatar
Was it correct prior to the cluster swap ?
The PCM is what is modified for adjusting the wheel ratio.
The factory tire for a '03 XLT is 255/70-16, which would have a rev per mile of 671
If you change to a 20" wheel and put 275/45ZR20 tires on it, the rev per mile is now 678.
My 2001 was off by about 4 MPH with the factory tires on it, and I put on L wheels with 285/60R18 ( I think that is the size), which put it close to correct, at 640 RPM.
The other info, did you switch the gears on the truck ?
