need some help.....object name & place to purchase?
Old Jan 4, 2009 | 08:22 PM
EBXGSXR's Avatar
ok, im looking for these things. need one more to finish a wiring harness to install my new lights into my truck. im not sure what they are called. basically, the stock wiring harness plugs into this and then it that splits the wires to go to 2 bulbs (one for high & one for low). anyone know what they are called or where i can buy them?
hope someone can help.
Old Jan 4, 2009 | 11:31 PM
SSCULLY's Avatar
bulb connector ?
You would need one for the bulb type you are plugging into, and then for the bulb type you are installing.
The bulb number has different pin outs, so they are different per bulb
Not sure what MY your truck is, your profile does not say, so I don't know if you are looking for a H13 on the truck end, and then the bulb type you are installing could be a 9007 ( one of the high / low bulb types )
Old Jan 4, 2009 | 11:57 PM
EBXGSXR's Avatar
ok, i didnt know if there was some fancy name like flex capacitor bulbs connecting assembly or something like that, lol. any idea on the best place to get them? an i would be looking for a 9007 connector.
Old Jan 5, 2009 | 08:37 AM
SSCULLY's Avatar
Not 100% sure, but I would think Autozone. KYO sells a pigtail that they call a harness upgrade, looks like this
These are really just an extension, that if the connector is melted from running the "100 W HID wana-be bulbs" that it only melts the pigtail, not the factory connector, is the concept I guess ??
I not, google 9007 connector, you can order them online.
Old Jan 5, 2009 | 09:43 AM
harly4d's Avatar
Headlight pigtail harnesses:
They have them all here:
http://www.suvlights.com/product_inf...roducts_id=215
Old Jan 5, 2009 | 08:11 PM
EBXGSXR's Avatar
well, i went to autozone today, and they looked at me like i had 3 heads. guess ill have to order them on line & wait for them to show. thanks guys for all the information.
Old Jan 5, 2009 | 09:39 PM
blackedoutV6's Avatar
I used to work at vatozone and know for a fact they carry them.
If you get a chance to go back just look in the aisle with all the electrical connections and stuff. They should be there.
Theres alot of brilliant people that work at those stores
Old Jan 5, 2009 | 11:21 PM
EBXGSXR's Avatar
lol. i did see that there were electrical plugs there, but i need the male portion. they had a bunch of replacement plugs like the female portion....or basically all teh stuff that is coming off of the vehicle's harness.
