Dim Headlights
Old Dec 20, 2008 | 11:01 PM
Sling's Avatar
Dim Headlights
I have noticed that my head lights are dimmer than usual (as did my passenger) on my 2004 FX4 SC. I havent tried turning them on manually yet. Brights seem ok so far. Any ideas?
Old Dec 21, 2008 | 05:23 PM
NoLongerJeepin's Avatar
Did you try replacing the bulbs?
Old Dec 21, 2008 | 09:06 PM
Screw-Me-05's Avatar
X2 :santa:
Old Dec 22, 2008 | 06:52 AM
Sling's Avatar
Yes.
Old Dec 22, 2008 | 03:16 PM
cansailorman43's Avatar
To add to the question. I have a 1998 with the right headlamp very dim. The left works fine. With DRL on it is extremely weak. With lights on it is at about what the DRL brilliance should be. The left light works fine. No difference in high or low beams. Any ideas. I pulled the right fuse and it seems fine. And yes changed the bulb.
Old Dec 22, 2008 | 11:59 PM
SSCULLY's Avatar
Did you check the ground to the right headlamp ?
