Windows stuck (DOWN)
Old Dec 20, 2008 | 03:10 AM
easyrydaddw's Avatar
Help please.
2003 F150 Supercrew 4x4
water damage
windows stuck
based on my research seems like the GEM and or fuse panel needs to be replaced.
in the meantime what procedure can i do to bypass the devices and send power directly to the window motors so that i can put up the windows?
i dont want to go another night with plastic on the windows.
i cant even tell which wires are going to the motor
Old Dec 20, 2008 | 11:07 AM
SSCULLY's Avatar
If it just the window, I would say switch or motor itself. It is about the right age if used a lot, to have a motor problem. Also could be damaged switch.
Might want to try a search, and this thread would show up :
https://www.f150online.com/forums/el...dow-motor.html
I just added back in teh pictures of the holes to drill and the motor out of the door. The connector you are looking for through the speaker opening ( after removing the speaker ) is the one shown in the motor pictures.
Just apply DC power to that connector, if it does nothing, reverse the polarity. If it still does nothing follow the directions in the thread above, you have a bad motor.
Old Dec 20, 2008 | 08:04 PM
thanks.
