I want a key without a chip
Old Dec 17, 2008 | 11:03 PM
FARMALL99's Avatar
Is there a way to change or reprogram the computer so I don't have to have a key with a chip in it. I cary several keys and I would like to have a key that is thin. Any thoughts?
Old Dec 17, 2008 | 11:06 PM
FX41's Avatar
sorry, your out of luck as far as I know.
Old Dec 17, 2008 | 11:22 PM
4play2008's Avatar
you caan take one of your chipped keys, and zap strap it to the inside of your steering collum plastic as close to the ignition as posible and it just might be close enough to have the vehicle sense it
Old Dec 18, 2008 | 03:47 PM
02SC4x4's Avatar
this is possible. i remember one of the other members doing this because he only had one key that was programmed and was to cheap to pay the dealer to reprogram the other ones. so he got a few cut and taped the coded one to the inside of the shroud.
Old Dec 18, 2008 | 03:55 PM
yetti96's Avatar
Explain that one to insurance when they recover the car with a factory key in it, lol.
Old Dec 18, 2008 | 05:18 PM
FARMALL99's Avatar
Talking
Thanks for the input. I think I will try it. If it doesn't work I'm not any worse off.
Old Dec 18, 2008 | 05:28 PM
SSCULLY's Avatar
Dumb question, do you have a remote start in the truck ?
I seem to recall a member doing some testing where the PATS bypass did the PATS enabling, and he used a regular key.
I cannot recall if it is a Code alarm / Ford type where the PATS bypass does not have power until the remote start tells it to ( he to remote start the truck, then use straight key )
or another brand, where the PATS bypass uses another key already coded to the truck, and is always active.
Old Dec 18, 2008 | 10:04 PM
FARMALL99's Avatar
I don't have a remote start. Maby in the future but not right now.
Old Dec 18, 2008 | 11:20 PM
4play2008's Avatar
if u wat you can cut the metal key part off and just have the plastic square of the key that way if anyone finds it they cant use the key ayway
Old Dec 19, 2008 | 08:00 AM
projectSHO89's Avatar
This is what I did with my wife's 98 Conturd this fall when I installed a new remote start in it. Instead of spending another $30 for a PATS bypass module, I just removed the antenna from around the cylinder, zip-tied the keyhead into the antenna, then mounted the assembly up under the dash. All the original PATS keys will work like normal (only the PATS keyhead is being read) plus I can used inexpensive blanks from now on.
Steve
Old Dec 19, 2008 | 10:18 PM
FARMALL99's Avatar
Just a thought, if two pats keys are too close to the pats sensor antenna at the same time will it confuse the system.
Old Dec 19, 2008 | 11:33 PM
Yes, it can. that is why i did what I did on the wife's car.
Steve
