No power to pump
Old Dec 10, 2008 | 08:19 PM
johnsec's Avatar
Cool No power to pump
I have a 2001 F-150 XLT with a 4.6. This truck has only 82,000 on it and has always ran fantastic. All of a sudden my fuel pump has no power. Checked fuses, relays, ect. Cannot seem to find problem. Relay under hood is good and I have power there. I dont have power at the inertia fuel shut-off switch behind the kick panel. Truck done this once before about a month ago then recovered on its own. It will roll over fine but no fuel. Any idea's??
Old Dec 11, 2008 | 03:08 PM
SSCULLY's Avatar
How did you come to "Relay under hood is good" ?
Old Dec 15, 2008 | 05:14 PM
johnsec's Avatar
tried another
thanks for replying. I tried the relay in a 2003 F-150 (company truck), worked fine in it!!
Old Dec 16, 2008 | 09:12 AM
SSCULLY's Avatar
Here is a thread that I posted a while back when my 2001 would not get fuel to the fuel pump.
The jumper in the fuel pump relay socket will show if it is a relay or fuel pump problem.
Did you check both fuel pump fuses ? ( you make no note of this ).
you can pull the fuel pump relay, and check the power to it with a meter, if you don't want to change the fuse.
