Wire from engine into cab????
Old Dec 10, 2008 | 04:56 PM
Drkharbinger's Avatar
Question Wire from engine into cab????
How do I get the wires for my PIAA's into my cab for the switch? Or is there a way to not use the switch at all so I don't have to run wires in? I have searched and found alot of useful info, just need more. Thank you to any who can help.
Old Dec 10, 2008 | 05:11 PM
NoLongerJeepin's Avatar
I ran mine through the firewall down by the gas pedal. There's 2 rubber plugs down there that some wires through. I cut a small hole (making sure not to hit the wires) in the plug and ran my wires through it. Then ran the wires behind the trim and put the switch up next to the steering column.
Sorry for the blurry picture, but you get the idea.
Old Dec 10, 2008 | 05:41 PM
These lights have separate modes. Is there a way to just wire them to the headlights so I don't have to deal with the switch?
Old Dec 10, 2008 | 05:57 PM
yetti96's Avatar
Yes but are you allowed to legally have them running at all times and will they not blind people? Most states only allow 4 forward facing lights.
Old Dec 10, 2008 | 07:43 PM
Anyone have a pic of where they put their relays and fuses? I have 2 of each and there is no where to put them.
Old Dec 10, 2008 | 11:55 PM
Thanx SSC!! That worked!
Old Dec 11, 2008 | 11:00 AM
SSCULLY's Avatar
Just like math class, you must show your work to get credit
Now stand up in front of the ground, and share
Old Dec 12, 2008 | 06:17 PM
Hehehe....got it. Gonna put it over in the other section Appearance Products where others asked for it. Thanks again everyone.
