Keyless entry module?
Old Nov 27, 2008 | 04:01 PM
trx450er's Avatar
I just bought a 2004 f-150 fx4 with a regular cab and I dont know the keyless entry code. I heard if you have an extended cab or a crew cab you take the back seat out and its on the black box (BCM). But since I dont have a back seat, I pulled the plastic off the rear wall and there was no box?
So where could I find the black box? Any ideas
Old Nov 27, 2008 | 11:08 PM
SSCULLY's Avatar
standard cab trucks, the BSM/VSM is located under the rear driver's side speaker under the c-pillar trim panel.
Old Nov 28, 2008 | 05:56 PM
trx450er's Avatar
Thanks I found it and it worked.
Old Nov 30, 2008 | 10:15 PM
bm01340's Avatar
are you able to change the passcode for the module?
Old Nov 30, 2008 | 11:19 PM
yetti96's Avatar
You can add a personal code, but the stock code will always remain. It is all in your manual.
